Which Edition?
ubmill
Which Edition?
Post by ubmill »
How can I tell what edition (Premium or Standard) that I am currently using?
I'm happy with the edition I have, but it needs to be updated.
Re: Which Edition?
thanks for your interest in upgrading Syncovery!
To find our which edition your are using, you can go to the Help menu and choose the item "Registration". You should see the registration name on the dialog box, but the code is hidden. Click OK and you should see a confirmation message.
It will mention the product as either:
Syncovery
Syncovery Pro
Syncovery Premium
and some additional details.
Just "Syncovery" means Standard Edition.
To upgrade, please visit www.syncovery.com/upgrade/ and enter your old license code. The upgrade system won't offer editions which are lesser than your previous one anyway, but you can reduce the quantity if needed.
If you don't have the license code any more, you could look for RegCode in Syncovery.ini or contact support by email to support@syncovery.com.
Thanks!
ubmill
Re: Which Edition?
Post by ubmill »
Thank you very much!
