Bug report: Profile disabled status
» by
Post by » by »
Syncovery 10.14.6
Windows 11
Relatively minor (but confusing) UI bug:
When I disable a profile, the main window shows the disabled icon, and the context menu for the profile shows "Enable" rather than "Disable". This is correct behavior so far.
But if I manually run the profile (and click "Yes" when prompted to "Run anyway?"), the disabled icon is replaced with the normal icon, and the context menu goes back to showing "Disable". However, the profile is still actually disabled.
If I try running the profile again, I'm prompted to "Run anyway?" Also, if I open the profile settings, it says "Disabled - click here to enable".
The workaround is to either "click here to enable" as mentioned just above, or select "Disable" on the context menu (which won't actually do anything, since the profile is already disabled), at which point the context menu will once again correctly show "Enable". Then, of course, you'd click "Enable".
» by
Re: Bug report: Profile disabled status
Post by » by »
Did I do something wrong? Should I email this bug report instead?
sorry for not replying yet! Yes I saw the report and will see what can be done!
In general I do prefer bug reports to support@syncovery.com but it's OK!
