Is it possible to auto rotate S3 secret key?
dean
Post by dean »
My company has a policy for secret key rotations every month.
Is it possible to configure Syncovery to fetch the secret key from a file?
Thanks in advance!
Dean.
Re: Is it possible to auto rotate S3 secret key?
yes, it can be read from a text file using a PascalScript, please see
I hope I can write an example tomorrow.
dean
Post by dean »
tobias wrote:
Thu Nov 10, 2022 9:02 am
Hi.
Thank you for the quick reply.
An example script would be very helpful.
Thanks again.
Here it is. You can put it in each profile via Job->PascalScript, or globally for all profiles via the Program Settings dialog, tab sheet Advanced.
const cTextFilePath='C:\code19\X.txt';
function OnGetProfilePathBeforeListing(const isRightSide:Boolean;
        var Path,UserName,Password:UnicodeString;
        var AuthKey,AuthKeyPassword:AnsiString;
        var Port:Integer):Boolean;
var F:Opaque;
    NewPass:UnicodeString;
  if Copy(Path,1,5)='S3://' then begin
     F:=OpenTextFile(cTextFilePath);
     if F<>0 then begin
        NewPass:=ReadLine(F);
        CloseFile(F);
        if (NewPass<>'') and (NewPass<>Password) then begin
           Password:=NewPass;
           if isRightSide then
              SetProfileProperty('RightPassword',NewPass)
           else
              SetProfileProperty('LeftPassword',NewPass);
           SaveProfileSettings;
  Result:=true;
