Backup of large .pst file to S3
Athena
Post by Athena »
I have a backup task copying data Windows Server to S3.
A large (13 GB) .pst file has been added.
Backup to local NAS is working fine, but backup to S3 fail.
Error is : File too big for server side copying or renaming of type ERunException at 00000000027E6423
Version of Syncovery is 10.18.4
How can I enable the backup of this file ?
Thanks in advance for your help.
Re: Backup of large .pst file to S3
The latest Syncovery 11 supports this.
It will also work with Syncovery 10 if you make sure that it doesn’t need to move or rename the file within the S3 cloud.
For tips to avoid this, please send the log file to support@syncovery.com.
