Scroll bar behavior on Mac
farhadd
Post by farhadd »
I have Syncovery 11.14.0 running on Mac OS 15.7.5 (Mac Mini M4). I have well over a dozen profiles and I find that the scroll bar behavior in Syncovery isn't consistent. The bar takes up the entire right edge of the window and won't let me drag it up and down. I can use my scroll wheel but when I get to the bottom the status bar at the bottom of the app hides some of the last profile's info. Resizing will make it redraw correctly sometimes. This as a problem in 10.X as well on an Intel mac mini which I just migrated to this installation. It's not preventing the software from working, but it'd be nice if it could be addressed. Thanks. I do have a video of the behavior but I'd rather not post it in this forum.
Re: Scroll bar behavior on Mac
Thanks for the report, I will look into it!
the new version 11.15.2 should fix this now.
Many thanks for bringing it to my attention!
farhadd
Post by farhadd »
Yes it does appear to have solved the issue! Thank you so much!
