Remote Service not getting upgraded when you "Check For Update.."
james_c_stein@fd.org
Post by james_c_stein@fd.org »
When you upgrade via the Check For Update option the remote service does not get upgraded.
Downloading and installing manually I can update it, but it isn't updated when you use Check For Updates.
Re: Remote Service not getting upgraded when you "Check For Update.."
thanks for the info!
Do you remember if the checkmarks for the remote service were chosen when you run the setup manually? Or did you need to choose them?
Because I believe the Setup program just remembers the previous choices.
It was not selected when I ran it manually. This is an install that was an upgrade from back before the name change. Maybe even before the remote service was even an option. Though I somehow got it installed.
