Hi
I created a profile to mirrored a flash drive that is labeled as "New Volume" to a folder.
But when I connect another flash drive with the same label to the system, the software scans the wrong device!
Cannot find the right device and back up the wrong device!
Please fix this bug.
Inability to identify the correct drive
- #2.png (6.87 KiB) Viewed 11730 times
- #1.png (40.43 KiB) Viewed 11730 times
Re: Inability to identify the correct drive
please do not use the "Device" button for flash drives.
Instead, identify them by drive letter, such as F:\ and use the normal Browse button to choose a folder.
Again, do not use the Device button.
To make Syncovery find the correct drive letter automatically, you can also identify them via volume label. Make sure each drive has a unique volume label. Then type paths like this:
VolLabel:\Folder
VolLabel:\Folder
I use "Device" button for a external hard derive that is same label as a system hard partition. But Syncovery can't find the correct one!
If i use drive letter for identify it, some time it changed depended on connected device to system.
VolLabel:\Folder
VolLabel:\Folder
Just make sure you give each drive a unique volume label please. You should not leave them named as "New Volume".
I actually see what you mean now. Syncovery has to find the drive letter for MTP drives, because accessing them by drive letter is much faster than using the MTP protocol. But it looks only for the volume label. I'm not sure if this can be changed.
Again, make sure your drives have different volume labels, unless you want Syncovery to consider them to be the same drive.
Hello again,
I have thought about it some more and I will change something.
If there are duplicate volume labels, Syncovery will just continue using the MTP protocol with the drive, even if it is much slower. It will also issue a warning telling the user about this problem.
Again if you have unique volume labels, it will be much better. Syncovery will be able to identify the drive and access it with high performance via the drive letter. But it needs the volume label to find the drive letter, because the MTP API does not reveal drive letters.
The new version 9.35d now warns if a removeable drive is chosen via the Device button and the volume label is not unique. Syncovery needs the volume label to identify the drive.
