Need new service - "Yandex Object Storage" :)
pnzdevelop
Post by pnzdevelop »
Hi! Yandex Object Storage, NOT Yandex.Disk.
info link = https://cloud.yandex.com/services/storage
Universal, scalable solution for data storage. The perfect choice both for high-load services, which require reliable and fast access to data, and projects with minimum requirements for storage infrastructure.
You can manage data access with popular tools to work with object storage — the service API is compatible with the Amazon S3 API.
Very important - API is compatible with the Amazon S3 API :P
Re: Need new service - "Yandex Object Storage" :)
S3 compatible APIs can be accessed by choosing S3 in Syncovery, and adding the server URL after the bucketname, like this:
bucketname@server.url
An example for Wasabi:
bucketname@s3.wasabisys.com
With Yandex, I believe it should be:
bucketname@storage.yandexcloud.net
