Lib folder on Monterey
smallboxes
Post by smallboxes »
Hi, I'm a new user trialing Syncovery - I have the latest Mac version running on MacBook with macOS Monterey
I'm using Syncovery to replace OneDrive client and it all seems to be working well except I have an empty 'lib' folder appearing in my user and it's driving my OCD nuts :roll: - is this necessary? Can I turn it off or hide it?
Simon
Re: Lib folder on Monterey
thanks for the report. It sounds like a bug, I will look into it and fix it.
smallboxes
Wow, thanks for the fast reply. Do you need any more information?
Cheers
Simon
I will check if I can see this folder on my machines, if not I will ask for log files probably ...
smallboxes
Hi, after some more investigations, the appearance of the 'lib' folder coincides with the background scheduler starting up.
I have Syncovery set to start on login, and if I delete the lib folder after this it it does not return until Syncovery restarts. Deleting does not seem to affect Syncovery operation once running.
Other than that Syncovery is f**kin' sweet!
Cheers
many thanks, I will fix it in the next update.
the new version 9.46g no longer creates the lib folder.
I hope you can confirm the fix.
Thanks!
