Change Email Notification Strings
ForestCat
Post by ForestCat »
I have users which simply cannot be made to understand that "can't access right path" really means that THEY HAVE NO BACKUP.
Is there a way to, for example, change "can't access right path" to "BACKUP FAILURE! CONTACT SUPPORT IMMEDIATELY" in the notification email subject?
Thanks!
Re: Change Email Notification Strings
yes, you can add a global PascalScript on the Program Settings dialog, tab sheet Advanced, to customize emails.
Please see
You can use this script:
function OnSendEmail(const ProfileName:UnicodeString;
                    var TheSubject:UnicodeString;
                    var HighImportance,UseDigest:Boolean;
                    var ResultSummary:UnicodeString;
                    const SomethingWasDone,ErrorHasOccurred:Boolean;
                    const FailedPathsCommaText:UnicodeString;
                    const StartedAt,EndedAt:Double;
                    var RecipientsCommaText:UnicodeString;
                    var SenderName:UnicodeString;
                    var SenderEmail:UnicodeString):Boolean;
  if Pos('can''t access',TheSubject)>0 then begin
     TheSubject:='BACKUP FAILURE! CONTACT SUPPORT IMMEDIATELY';
     HighImportance:=true;
  Result:=true
ForestCat
Post by ForestCat »
Thank you, Tobias. You are the best. Really.
