Support of OpenStack Swift cloud storage?
Nei
Post by Nei »
Hi there,
do you support OpenStack Swift compatible cloud storage like OVH Germany https://www.ovhcloud.com/de/public-clou ... t-storage/ or Swiss Backup https://www.infomaniak.com/en/swiss-backup/? I see Rackspace cloud storage supported and up to my knowledge Rackspace uses OpenStack for their storage infrastructure.
Best,
Nei
Re: Support of OpenStack Swift cloud storage?
unfortunately it is not supported. I hope I can add it, possibly in Q4 this year.
Nei
Post by Nei »
Hello Tobias,
thanks for getting back on my suggestion.
An OpenStack Swift solution should not be that far away after you have already successfully implemented the the Rackspace cloud storage. However, to connect to Swiss Backup for example you need these OpenStack Swift values when you connect via Rclone:
type = swift
user = [user name]
key = [password]
auth = https://swiss-backup.infomaniak.com/identity/v3
domain = default
tenant = sb_project_SBI-[tenant name]
tenant_domain = default
region = RegionOne
storage_url = leave blank
auth_version = leave blank
our Rackspace API implementation is not related to OpenStack. Not sure why you mention that.
https://developer.rackspace.com/docs/cl ... -reference
But our Hubic connector does use OpenStack, so that's something that could be built on.
Nei
Post by Nei »
tobias wrote: Fri Jul 03, 2020 2:40 pm our Rackspace API implementation is not related to OpenStack. Not sure why you mention that.
Of course Tobias, you are right. I was somehow on the wrong pathway, Hubic/OVH or Swiss Backup are the ones I meant utilizing OpenStack Swift storage technology.
I am really looking forward on the addition of this cloud storage technology to Syncovery.
Nei
Post by Nei »
Hello Tobias,
just wanted to get back on the OpenStack/Swift cloud storage support. You mentioned that in Q4/2020 there might be a chance for implementing this cloud backend in Syncovery. So I thought I ask for any update of your plans towards this.
