Different Checked vs. Check in Group
RoyReddy
Post by RoyReddy »
I experience Different Checked vs. Check in Group
Version 10.3.6 build 66
on Windows 10
see the attached screenshot
Profile Group
Profile Group
Screenshot 2023-03-17 161148.png (34.69 KiB) Viewed 10156 times
Run Checked Profiles in Group "work Ext" in Background does nothing
Run Checked Profiles in Background = works all 5 profiles run and complete
same behaviour on Version 10.3.13 build 73, does nothing
Re: Different Checked vs. Check in Group
Thanks, I will look into it!
Version 10.3.14 should fix this now. It affected only user-defined groups which were not using the traditional "first word is group name" scheme.
RoyReddy
Post by RoyReddy »
confirmed here
Version 10.3.14 fixed. Run Checked Profiles in Group "work Ext" in Background succeeds
thank you
