OAUTH ERROR with pCloud
janine
Post by janine »
OAUTH error started with pCloud last week. I updated Syncovery (Mac) to the latest version but the issue still occurs. Is anyone else experiencing the same issue? My OS is Catalina 10.15.6. Any advice/workaround would be appreciated. Thank you!
Screen Shot 2020-08-04 at 13.00.46.png (230.42 KiB) Viewed 19826 times
Re: OAUTH ERROR with pCloud
thanks for the report!
The Mac version doesn't work with the new "European" accounts of PCloud yet.
I will update it today and let you know when the update is ready.
janine
Post by janine »
Thank you Tobias! That would be awesome!
can you try it again now? I just fixed something on my web server that aids with the authorization. You probably do not need any Syncovery update.
A Syncovery update would only be needed if you chose the European data region when signing up for PCloud.
janine
Post by janine »
It works now! Thank you Tobias!
