Disable file converstion with two way Google Drive Sync
IMTheNachoMan
Post by IMTheNachoMan »
I'm doing a two way sync of files on my Linux box with my Google Drive.
I have Enable Document Conversion disabled but it still converts Google Doc files.
Re: Disable file converstion with two way Google Drive Sync
I will check it. With these settings it should skip the files.
But of course it won't skip a local png file.
IMTheNachoMan
What do you mean it won't skip a local png file?
When you say it should skip those files, do you mean it would not download Google Doc files from Google Drive?
Is there a way to make .lnk/.url files locally that point to the Google Drive file such that when I open them from KDE, they open my browser to that URL?
there is no way to copy a native Google Doc from one Google Drive to another, except by converting it on download and then again on upload. You should work with Shared Folders instead.
Yes Syncovery can create links instead, see the checkmark "Create Links to Online Docs".
IMTheNachoMan
I was thinking of copying it as a .gdoc file like Google Drive app for Windows does.
I tried the create links option, but the file doesn't seem to be shortcut my computer understands. Let me try again.
IMTheNachoMan
Okay, so I figured it out.
Syncovery is creating Windows style URL files but Linux does not understand them.
Is there a way to get it to create Linux URL files?
IMTheNachoMan
It looks like Syncovery creates a drive URL instead of the appropriate Docs/Sheets URL. Is it possible to change that behavior?
For example, it creates this:
[InternetShortcut]
URL=https://drive.google.com/file/d/1xvkhxAgHnFPZEJNOd5h2ThCqzjzj2mE7hPmZ1X8uUVY
I'm hoping I can get it to create this:
[InternetShortcut]
URL=https://docs.google.com/document/d/13dBbChOzBOZHr-betdor6-IVjn8QaQbdfTEZ1LHh9dA
Maybe in a future version, yes.
IMTheNachoMan
tobias wrote: Sun Feb 18, 2024 3:54 pm Maybe in a future version, yes.
Got it.
If it helps someone else, here is how I fixed this for now.
I created the following BASH script and told my file explorer to open .url files with this script.
#!/bin/bash
grep -h -s --color=never '^URL=' "$@" | cut -d'=' -f2- | xargs sensible-browser &
