HTTP ERROR 409 Conflict - Name already exists
Paradoxical
Post by Paradoxical »
Partial log:
2/25/2024 11:28:35 AM OneDrvNew: Starting upload of sample.docx (4011306 Bytes)
2/25/2024 11:28:35 AM OneDrvNew: Starting upload of sample2.docx (739339 Bytes)
2/25/2024 11:28:40 AM OneDrvNew: Exception uploading sample2.docx: HTTP ERROR 409 Conflict
{"error":{"code":"nameAlreadyExists","message":"Name already exists"}}: {"error":{"code":"nameAlreadyExists","message":"Name already exists"}} (ETGFTPErrorDoNotRetry), CP:CbEnqAbX
2/25/2024 11:28:40 AM OneDrvNew: Final exception uploading sample2.docx: HTTP ERROR 409 Conflict
2/25/2024 11:28:40 AM SynHttpsPut: HTTP ERROR 409 Conflict
{"error":{"code":"nameAlreadyExists","message":"Name already exists"}} (EHTTPSendException) @00000000025CD04F, ResultCode=409, Result={"error":{"code":"nameAlreadyExists","message":"Name already exists"}}
2/25/2024 11:28:40 AM ERROR (EHTTPSendException): HTTP ERROR 409 Conflict
{"error":{"code":"nameAlreadyExists","message":"Name already exists"}} @ 00000000025CD04F, Thread ID: 2892, CP: SHPutEX:HTTP ERROR 409 Conflict
{"error":{"code":"nameAlreadyExists","message":"Name already exists"}} (SynHttpsPut)
Both files were uploaded just fine to OneDrive for the very first time to a new account.
As soon as I modified the files and ran the profile once again, the error happened.
Syncovery v10.12.2, build 183 (64-bit)
System Info: Microsoft Windows 7 Professional Build 7601
Using Backup Privilege
Previous run was at 2/24/2024 11:16:14 PM: INCOMPLETE: 0 copied of 2, Errors with 2 File(s), Duration: 00:00:19
Connecting with OneDrvNew
RefreshAccess called for cloud ID onedrivenew
Using OpenSSL 3.2.0 23 Nov 2023: libssl-3-x64.dll, libcrypto-3-x64.dll
Exact Mirror Mode is being used.
Re: HTTP ERROR 409 Conflict - Name already exists
That's interesting, apparently Microsoft changed something. It doesn't happen with my old accounts.
I will sign up for a new one to test this.
Paradoxical
Thanks for having the time to look at it.
Also, now that you're into it, could you check OneDrive's file size limitation. Some files around 200 megs won't get uploaded though I don't know exact size they limit.
files over 200MB should not be a problem.
Can you send a complete log file with errors for large files to support@syncovery.com?
I also have a new version to test that should fix the 409 problem, which I would like to send to you privately.
Paradoxical
Version 10.12.3 fixed the 409 problem. Thank you.
As for the other issue, the file size issue, I have to run some tests...
Edit:
I said too soon. v10.12.3 is just ignoring the files, whether modified or new ones. The program indicates "Nothing to do" though. When I browse OneDrive folders via web browser, no files or folders are added of modified either.
Full log:
Syncovery v10.12.3, build 184 (64-bit)
Licensed to:
Running on :
Running as : ddddd/ddd  (not Admin)
Log for profile Prepa en Línea-SEP (OneDrive), started at 6:46:33 PM on 2/25/2024
LEFT: D:\Desktop\KIDDOS\MELANIE\Escuela\Prepa en Línea-SEP
RIGHT: ext://OneDrvNew/Escuela/Prepa en Línea-SEP
The profile is run in the background with Sync Preview
Previous run was at 2/25/2024 6:46:21 PM: Nothing to do, Duration: 00:00:05
Total System Memory at 2/25/2024 6:46:33 PM: 2048 MB, Available: 502 MB, Memory Load: 75%
Left Side Volume Name:                DATA
Scanning Folders Started At 2/25/2024 6:46:35 PM
2/25/2024 6:46:33 PM OneDrvNew: Verifying Access Tokens
2/25/2024 6:46:35 PM OneDrvNew: Connect Successful
Scanning folders took 00:00:02 (hh:mm:ss) for 1 folders
Total System Memory at 2/25/2024 6:46:38 PM: 2048 MB, Available: 499 MB, Memory Load: 75%
Free Space on left side :       111 GB, needed:    0 Bytes
Free Space on right side:  Not checked, needed:    0 Bytes
Main Copying Phase Started At 2/25/2024 6:46:38 PM
Main Copying Phase Ended At 2/25/2024 6:46:38 PM And Took 00:00:00
SUMMARY
Short Results: Nothing to do, Duration: 00:00:04
Operation completed at 6:46:38 PM on 2/25/2024
Total duration: 00:00:04
Local time zone offset :         -6.0 hours.
Internet protocol timeout :      60 seconds
Max. Internet protocol retries : 2
Time used for free space checks on left side: 0.0027 seconds for 2 space checks.
Profile Settings From E:\Syncovery\Data\Syncovery\Syncovery.ini
[General]
Name=Prepa en Línea-SEP (OneDrive)
LastModified=2/25/2024 6:43:57 PM
LeftPath=D:\Desktop\KIDDOS\MELANIE\Escuela\Prepa en Línea-SEP
RightPath=ext://OneDrvNew/Escuela/Prepa en Línea-SEP
Subfolders=No
LeftToRight=Yes
RightToLeft=No
UseSubfolderSelection=No
[Comparison]
AdjustFolderTimes=No
SizeConflictAction=scaCopy
[Exact Mirror Config]
ExactMirrorDeletes=Yes
ExactMirrorReplacesNewerFiles=Yes
[Files->Deletions]
RecycleDeletedFiles=No
[Internet]
RightFTPSettings=Ext:ExtProt=OneDrvNew,Flags=UTF8+ReplaceChars+UTC+DetectTimezone+ReplaceAutomatic+AvoidChangesAPIInitialListing,"Proxy=no",Lib=0
RightExtendedProtocolName=OneDrvNew
[Exclusion Masks]
ExcludeFileMasks=*.temp;*.tmp;*.iso;Sesión uno.mp4;Sesión dos.mp4;Sesión tres.mp4;Sesión cuatro.mp4;Quinta sesión.mp4;Sexta sesión.mp4;Séptima sesión.mp4;Octava sesión.mp4;Melanie- Actividad integradora - Cuál de las tres leyes es.mp4
[Safety->Unattended]
UnattendedOverwriteNewer=Yes
UnattendedDeleteFiles=Yes
UnattendedDeleteMaxPercent=50
UnattendedDeleteMaxFiles=10000
Default System Codepage: 1252
Total System Memory at 2/25/2024 6:46:38 PM: 2048 MB, Available: 498 MB, Memory Load: 75%
Email Notification Settings:
Email Notification is OFF.
Notification not sent (again) due not Global.Email
no, that's impossible.
Please try again.
If Syncovery says "Nothing to do", there really is nothing to do.
You need to look into that in more detail.
For example, click on "Show All" in the top left corner of the Sync Preview to see all files that Syncovery sees, and scroll to the file and compare the timestamps and sizes locally and online (left/right). This will give you some useful information.
Theoretically it could occur that the timestamp on the destination is newer than on the source. In that case, Standard Copying will not overwrite the newer file, but Exact Mirror will.
If problems remain, please send a detailed report with screenshots and log files to support.
some more information. In general if Syncovery says "Nothing to do", that means that the files are already in sync. Syncovery may have uploaded or downloaded the files just moments ago, and then the next profile run produces "Nothing to do".
Note that the OneDrive page in your browser may not update immediately and you need to hit F5 to see the updated files. There could also be some delays in updating the view in your browser.
Of course there can be lots of other reasons for "Nothing to do", including incorrect profile settings or a subfolder selection.
I have now released version 10.11.3 officially on our web site, with some additional improvements.
Paradoxical
I'm sorry, my bad. I had misconfigured my OneDrive profile.
At the time of typing this message I'm running the profile successfully uploading 1.6 GB, let's see how it goes.
Using the public latest release 10.12.3
Thanks a lot for your superb product and support.
Paradoxical
Well, something happened, the profile stopped for around 5 minutes like this:
then this
now after two or three minutes this and it stopped again
OneDrive is a pain...
Paradoxical
After 25 min
