root-folder suddenly appears in OneDrive Sync
m.sebastian
I'm using a OneDrive-to-local-disk sync with 3 different MS-Home accounts.
Since about 3 weeks a root-folder suddenly appeared in 2 of the accounts in the sync, with subfolders containing nearly the same structure.
When this folder appeared, neither the OneDrive-account nor Syncovery had been touched.
This "root" folder is not visible within the OneDrive itself, also not in the online-version.
Can someone please give me a hint how to solve this problem?
Thank you in advance.
Regards
Markus
Regards
Markus
- Syncovery1.JPG (44.05 KiB) Viewed 99398 times
- Syncovery2.JPG (123.28 KiB) Viewed 99398 times
Re: root-folder suddenly appears in OneDrive Sync
that is hugely interesting! Please delete the cloud cache database from the folder
C:\ProgramData\Syncovery\Database
I hope this will fix it.
m.sebastian
Hi Tobias,
that did the trick, the root-folder is gone.
But still problems on one account, some folders cannot be accessed.
Those folders definately exist in OneDrive and I can access them (via the client and also online for sure).
Thank you for your help!
Markus
Syncovery version is 10.14.2 (64-bit)
Markus
- OD1.JPG (14.74 KiB) Viewed 99352 times
this could be difficult to solve, can you send a complete log file to support@syncovery.com please?
Thanks.
Thanks.
m.sebastian
Hi Tobias,
sent you the log.
Thank you.
Markus
sent you the log.
Thank you.
Markus
m.sebastian
Hi Tobias,
unfortunately the root-folder on both profiles is back.
As long as I delete the cloud cache database before starting the job manually, the root-folder won't appear.
When the jobs run automatically, the root-folder is coming up.
It makes no sense to exclude it, because it has a lot of files/folders in it.
Maybe there's a chance to get this problem fixed?
Regards
Markus
Regards
Markus
no, the root folder is a new feature of the OneDrive API.
If you don't like it, you can type
root
in the Exclusion Masks.
root
m.sebastian
Hi Tobias,
the thing is, that this root-folder contains a large amount of files and folders (I didn't put it in), so if I do not exclude it in the syncovery-job, I nearly have double the amount of storage space used for it with many duplicate files and folders.
If I exclude it in the way you mentioned above, some folders on the onedrive are not accessible within the syncovery-job and I get an error.
But the curious thing is, that if I delete the syncovery database-cache before running the job, the root-folder will not appear and everything is running without any errors. So that looks more like a syncovery-bug to me.
Do you have any information on this new "feature", cannot find anything about it on the web.
Thank you so mch for your effort!
Regards
Markus
Regards
Markus
I do not have any additional information. The new folder is simply reported by the API. I think it allows you do access some special folders which were previously not accessible.
Excluding it should not cause any errors. To ensure that it's only excluded on the top level, you can actually put this Exclusion into the Exclusion Masks:
/root
If there are errors, please send log files with errors to support@syncovery.com.
/root
Hi Markus and Tobias,
This discussion is very interesting. The "root-folder" issue seems tricky, especially with it using extra storage and causing errors when excluded. Have you tried syncing each account one by one to see if it works better? Also, does clearing the cache and running the job manually always fix the issue, or does it sometimes come back?
