Syncovery 11 Released for Windows
Syncovery 11 is now available on the Windows download page:
https://www.syncovery.com/download/windows/
It contains a few exciting new features and GUI improvements:
  • Redesigned Profile Editor dialog for improved user experience.
  • Redesigned Internet Protocol Settings dialog for easier configuration.
  • Updated Exact Mirror configuration dialog with new features for high availability server replication.
  • New Account Manager for managing Cloud/Internet Protocol accounts (accessible via the Internet dialog or File menu).
  • New File Integrity Scanner available under Verifications → Integrity in the profile settings.
  • Cloud-to-cloud copying now possible without using local temporary files.
  • Improved algorithm for detecting moved and renamed folders.
  • Option to specify separate versioning folders for both the left and right sides of synchronization.
  • SFTP Server is now included as part of the Syncovery Remote Service for peer-to-peer synchronization.
  • Profile Overview context menu now allows color selection for each profile.
  • Notes and comments can be added on the Information tab of each profile, appearing as tooltips when hovering over profiles.
  • Updated SecureBlackBox library for enhanced SSH/SFTP and PGP compatibility.
  • When using compressed packages with multiple files per archive, the number of packages kept at the destination can now be limited.
  • Automatic renaming of duplicate files on Google Drive is now supported.
  • Separate login credentials can be specified for Syncovery Remote Service communication, allowing the main account for copying to be read-only.
  • Various visual improvements across the interface.
It is a free upgrade for all licenses ordered since October 2022.
Upgrades for older licenses can now be ordered on our web site.
This is a truly exciting release and I look forward to creating the macOS and Linux versions in the next few weeks!
