i set up a profile with "Exact Mirror", with an empty folder to the left and the folder that i want to keep clean and tide, in the right.
I've put under mask & filters, the rule to detect the files age over 4 hours (for example), and the extension of the files that i want to delete.
It's all working fine, but i've seen in the log, that the profile wants to delete also the folder containing those files. Is there a way to avoid this ? The deletion not happen because the folder is not EMPTY.
In the exclusion mask i put the folder name that i don't want to be examined, but if i do this, then the whole folder is not processed, so i cannot delete files older than "x" days.
Is it per design or i'm missing some setup ? thanks
Delete files older than "x" days, but not folders
Re: Delete files older than "x" days, but not folders
the checkmark "Never Delete Any Folders" is under Folders->More in Syncovery 11, or simply Folders in older versions.
We got a very old version "7.80c"
It's time to upgrade
v8.30 for Windows (April 19th, 2019):
Adds a “copying order” option on the Special tab sheet with the choices
Standard (Alphanumerically), Smallest First, Largest First, Oldest First, Newest First.
Adds a checkmark “Never Delete Folders (only Files)”.
Fixes possible hangs uploading to Google Drive.
Fixes SyncoveryCL not working on Windows Server 2003 or Windows XP.
- folder-delete.png (10.01 KiB) Viewed 14502 times
yes, upgrading is probably a good idea!
Syncovery 11 feature a large number of improvements. Read more about it here:
www.syncovery.com/syncovery11/
Here's an article with our latest developments, including the Syncovery 11 announcement:
www.syncovery.com/documentation/news/la ... elopments/
And here's some news about the previous Syncovery versions 8, 9 and 10:
www.syncovery.com/syncovery10/
www.syncovery.com/syncovery9/
www.syncovery.com/syncovery8/
