Next Run is 13.12.3268 for all profiles
M_Meyer
Post by M_Meyer »
I updated Syncovery to the latest version 11.8.2 on Windows 11 and now saw that all scheduled profiles have a next run on 13.12.3268.
I doubt the Notebook or me will see this date alive...
This happened some time ago already (on a different machine) and it was quite annoying to re-schedule all profiles.
Could you have a look for this ?
Thanks!
Re: Next Run is 13.12.3268 for all profiles
What kinds of schedules do you profiles have, for example daily, hourly etc?
And do you have any limitations under "Weekdays and Time Window"?
A date like you mentioned can theoretically occur if you chose only a specific weekday but it can't be reached with the schedule you chose.
Doesn't stopping the scheduler completely and restarting it help?
M_Meyer
Post by M_Meyer »
The profiles are hourly with some minutes offset.
No limitations under "Weekdays and Time Window".
I didn't try simply stopping the scheduler and restarting it - I opened every profile for edit and saved it without any change. That brought the correct next run dates back.
But if it happens next time, I will try this.
Thanks. This isn't currently a known problem and there haven't been any changes with regards to scheduling lately.
Theoretically if you start the scheduler, it sets all times freshly and should make sure that they make sense.
