Mega Error since upgrade
trent066
Post by trent066 »
I upgraded to the latest version and now am getting the error "MegaCli2020.dll missing" when trying to sync with Mega. Any ideas or can I downgrade the version if its related to the upgrade?
Re: Mega Error since upgrade
maybe a DLL is missing. Are you using the 32-bit or 64-bit version of Syncovery? And which version exactly?
Did you install the new version over an existing installation?
I can see the problem on one of my test machines now. I am working on a fix.
It looks like you need the two DLLs attached to this post.
Please extract and copy the Syncovery Program folder, such as
C:\Program Files\Syncovery
They will be included in the next update.
VCDLLs.zip
(190.21 KiB) Downloaded 993 times
trent066
Post by trent066 »
That worked. Thanks.
the new installer for 9.39i also contains the DLLs correctly now.
