Exclude subfolders
JmK
Exclude subfolders
Post by JmK »
Just purchased a copy and am trying to work through filter exclusions.
Is there a mask that I can use to exclude all subfolders with a particular name. I imagine it would be something along the lines of *\bin\*.*
E.g. I would like to exclude all subfolders named "bin" and the result should be the exclusion of these folders:
\Test\android\bin
\Test\ios\bin
\Projects\Build\Output\bin
Thanks!
Re: Exclude subfolders
The best way is to type just
bin
This will exclude all items named bin everywhere, and of course subfolders too.
JmK
Post by JmK »
Thank you for the prompt reply!
That will probably work for most of the scenarios I need.
It would be perfect if I had a way of excluding just folders. This is good enough though.
yes this will be made more flexible in a future version.
Special requirements can currently be fulfilled with a PascalScript function. For example, to exclude only bin folders:
function OnIncludeItem(const FileName, RelativePath: UnicodeString;
        const isRightSide, isFolder:Boolean;
        const FileSize:Int64; const FileAttr:LongWord;
  Result:=not isFolder or (FileName<>'bin');
This can be added to the profile via "Job->PacalScript..." .
However if you have a really large number of files, the script might slow down the scanning process. This is definitely slower than the exclusion mask which I recommended.
See also
JmK
Post by JmK »
"yes this will be made more flexible in a future version."
Excellent! :D
User
Post by User »
tobias wrote: Fri Feb 16, 2024 8:52 pm The best way is to type just
bin
So there's no difference between "*bin*" and just "bin" without the "*"?
Syncovery Premium Family, Win 10
yes there is a big difference.
*bin* would exclude files and folders named for example
Robin Hood
Binary Files
dump.bin
But bin excludes just bin.
You could theoretically type *\bin\* but there is no reason to do it. It only makes the processing unnecessarily complicated.
