Unable to connect with Mega.co
Hawky33
Post by Hawky33 »
Hello, I can't connect with new count !!!
However old ount is good
Can you do something ?
Thanx
admin
Site Admin
Re: Unable to connect with Mega.co
Post by admin »
thanks for your message! Yes unfortunately this is a known issue. We have to update the Mega library and connector. The update has been delayed because we originally had a Mega C++ library with custom modifications made by Mega for us, and the newest library doesn't have those modifications. So it will be a bit of work, but I will now give this the highest priority, since a few customers have asked for it.
As you mentioned, Syncovery currently works with older Mega accounts only. I don't know exactly how old they have to be, but newer accounts are compatible only with a newer Mega library.
I'm sorry for the delay and I will now update it ASAP.
Hawky33
Post by Hawky33 »
Thank you for quick answer so now :
Final count down !!! :lol:
just a quick update, I am finalizing all other Syncovery 9 features now and publish a "Release Candidate" in the next 2-3 days, and then work on MEGA before the actual Syncovery 9 release. Which I hope to be able to make by the end of the month.
I have finally put V9 Release Candidate 1 on our web site, and will start working on MEGA tomorrow.
Hawky33
Post by Hawky33 »
I'm waiting for ...
Have a good job !
Thanx in advance.
I've got the new API working now. I will make some further optimizations and tests tomorrow and release it Monday or Tuesday (in both Syncovery 8 and 9).
the new version 8.67 is now available with these improvements:
  • Uses the latest Mega SDK to work with newer Mega accounts.
  • Can set last modification timestamps when updating files to Mega.
  • Faster Mega Login at the beginning of a profile run.
  • Less memory usage when uploading to Mega.
  • Can now rename and move files and folders on Mega.
  • Fixes problems with folder names with leading or trailing spaces.
  • Fixes Mega related crashes and other bugs (such as when canceling a download).
The next Release Candidate for Syncovery 9 will feature the same improvements.
Hawky33
Post by Hawky33 »
Well doesn't work for old and new mega accounts !
MegaCli2020.dll access problem ...
probably a DLL missing in the French installer, I'll check it and fix it.
